I have a question about sample triggering. When using a rmx/denon kind of midi device. Can the samples be triggered by another unit like a mini korg $49.99 keyboard? Using both at the same time? there are several units $49. kinds of midi devices.
geposted Sat 14 Nov 09 @ 11:35 pm
Good question. I had asked this on another thread. Would be very interested in an answer to this.
Roy
geposted Sun 15 Nov 09 @ 2:48 pm
Yes, you can use multiple MIDI controllers. If the controller is not already supported, you will need to map it yourself https://virtualdj.com/wiki/VDJscript.html For a basic MIDI piano keyboard, the default Simple MIDI Wrapper should be sufficient.
You would map keys to sampler 1 play_stop, sampler 2 play_stop, etc.
NOTE: If the keyboard doesn't have its own built-in USB MIDI interface, you will also need a USB MIDI cable, or a sound card with built-in MIDI interface.
geposted Sun 15 Nov 09 @ 3:08 pm
Thanks JP.
Roy
Roy
geposted Sun 15 Nov 09 @ 3:12 pm
I got the cable and will be working on this. It will work great and will post info an a youtube video on how to do it. Its going to rule. I want to be able to set up 2 of them one for visualations and the other for samples.
geposted Tue 26 Jan 10 @ 11:18 pm
i currently run a korg zero 4 via firewire for midi and a nano pad via usb for midi at the same time and have no problems with them at all and i def hit the buttons, knobs, sliders etc a lot.
geposted Wed 27 Jan 10 @ 1:39 am
verry cool,I thank you fpr posting it , All it does is give me ideas for building club setups. I know 20 grand for the big club is nothing for extras if I can build a out of control system , I will man it and charge massive dollars. Show me the money and I will show you the goods...
geposted Wed 27 Jan 10 @ 1:38 pm
