Greets to all of you good people!
I have searched the forums for some DJC Skins, but i have found none. As you all probably know,
DJC is technically VDJ version 3, so i was wondering are there any other skins for us LE users?
Resolution of the skins is 1024x768.
Midi contrroler Hercules DJ Control Mp3 E2
Can anyone help?
Thanks in advance!
Can anyone help?
Thanks in advance!
geposted Sun 15 Nov 09 @ 6:06 am
To sum up.
Can i change the default DJC_Edition skin with some other skin?
geposted Sun 15 Nov 09 @ 5:22 pm
There are some skins designated for LE users who have the DJC edition of VirtualDJ. Your just going to have to look for them.
geposted Sun 15 Nov 09 @ 6:44 pm
Thank you.
Yes, i found those skins, but the next problem comes up...
In my skin folder i have the "DJC_Edition" skin.
I downloaded a skin from database (VDJ version 3 compatible), and copied it into skins folder.
Then i deleted the "DJC_Edition" skin, and renamed the newly downloaded skin as "DJC_Edition".
An error occurs when i try to load the program.
It says something like: "Error in line 0 of the xml"...
I have been trying all sorts of things to solve the problem but had no success... It simply can not load other skins...
Can anybody help? I'm preety much clueless and dont know what to do...
geposted Mon 16 Nov 09 @ 2:18 am
Nevermind... I'll just use the default skin... :(
Thanks anyway! ;)
Thanks anyway! ;)
geposted Mon 16 Nov 09 @ 2:52 am
Did you ever figure this out. I tried the same thing. Have an RMX with DJC.
geposted Thu 07 Jan 10 @ 8:16 pm
how to get dj/io numark i.m stay in indonesia
geposted Sat 04 Dec 10 @ 7:52 am
