I have 2 XP10 controllers. When hooked up to my mixer, I notice a difference in the sound quality. Quality in the sense that one card is noticably louder than the other and I confirmed it by switching the controllers.
Any suggestions?
BTW How come my status does not reflect the 2XP 10 controllers.
Mx
Any suggestions?
Mx
geposted Wed 04 May 05 @ 11:05 pm
Check to see if windows has automatically lowered the volume of the quiet soundcard. On my system, windows defaults the soundcard volume to half when it detects a new soundcard.
Go to your windows volume properties (probably a little speaker icon in the bottom right next to the time), go to options, select both USB speakers 1, and USB speakers 2 and make sure they are both set to max.
Hope this helps!
As for not having the XP10's listed in your title....well, me either. You have to purchase the VDJ version of the XP10 from Atomix to get that. Purchasing the retail version of the XP10's from EKS or another reseller (as I have) will not get you the groovy title. =)
Hope this helps!
geposted Thu 05 May 05 @ 7:40 pm
