hey folks, for some readon i cant get more than one effect to work..when i try to add another it erases the last one i had..can u only add one effect on the skin/please help..thanks...
geposted Tue 17 Nov 09 @ 4:38 pm
Look for skins with more than one effects slot on - i have created a few with multiple slots. You should then be able to load two, three or more depending on your system specs. I have had all six running at once (only to test it)
Black Sheep was my latest skin with multiple effects slot 1440x900 but i know someone has posted a smaller version of it too. =)
geposted Tue 17 Nov 09 @ 6:14 pm
As above, but you can also use shortcuts (keyboard/MIDI) to activate multiple effects too.
geposted Tue 17 Nov 09 @ 6:35 pm
I use the Darkfun skin and am very comfortable using it but I still cannot map 1 effect per bank slot. I have 3 other banks that are empty and I'd like to assign a different effect to each one.
geposted Thu 19 Nov 09 @ 2:49 pm
Use spin in one Echo in the other... Cheers.....!!!
geposted Sun 22 Nov 09 @ 11:25 pm
