Is it possible to play a standard audio file (e.g. mp3) when in Video mode and use the artwork of the audio file as a still image instead of a video? It would be nice to be able to project the image associated with the audio file if possible. Thanks.
geposted Tue 17 Nov 09 @ 5:59 pm
There is a plugin available by djcel called "ShowCover" :)
geposted Tue 17 Nov 09 @ 6:46 pm
Cheers for the heads up. I installed that but it doesn't seem to be compatible with 6.0.x because I got the following error when I tried to enable the effect:
VirtualDJ: virtualdj.exe - Unable To Locate Component
This application has failed to start because d3dx9_32.dll was not found.
Re-installing the application may fix this problem.
any ideas how this can be resolved? Thanks.
geposted Wed 18 Nov 09 @ 2:50 am
Just after doing a bit of a google on it now too and it would appear this is related to DirectX. After installing the updates it looks to be working okay now. Will have a play around with it and see how it goes. Thanks again.
geposted Wed 18 Nov 09 @ 2:52 am
