I just updated my new Denon DN-HD2500 with the latest firmware how do I make sure all of the buttons corispond properly with VDJ functions for example the three FX buttons seem to be assigned to the wrong effects how to I change this?
For example FX2 is a Backspin effect but needs to be a flanger effect how and FX3 seems to also be assigned to the Backspin effect when it should be the Filter effect.
geposted Thu 19 Nov 09 @ 2:39 pm
Updating just the device's firmware should not of changed the mapped FX assignments. Unless the firmware upgrade changed the MIDI code assignments.
Have you customized the mapping at all ?
geposted Thu 19 Nov 09 @ 4:57 pm
I just got the unit today... it had firmware v1001 on it so I updated to the latest from the Denon website which is v1400.
I haven't customized the mapper in VDJ v.6.0.3 and am using the defualt settings in he mapper.
geposted Thu 19 Nov 09 @ 5:10 pm
Go into CONFIG -> Mappers and choose the HD2500 from the drop-down list.
Click + (Add) and press the FX button you wish to change.
Type one of the following in the action box, as appropraite:
effect 'backspin' active
effect 'flanger' active
effect 'filter' active
(You can use the name of any effect of your choice in the '')
geposted Thu 19 Nov 09 @ 8:17 pm
Thanks I'll give that a shot... does the name of the effect need to match presicely how it is in the effects selector in the skin?
They need to be FX1 - Echo, FX2 - Flanger, and FX3 - Filter
I'm sure I can figure it out for myself so I'm just looking for validation that I'm doing it right.
Thanks
geposted Fri 20 Nov 09 @ 12:47 am
The name needs to match the filename of the effect, which in most cases should be the same as displayed in the selector on the skin.
If you are not sure, you can always browse to My Documents -> VirtualDJ -> Plugins -> SoundEffect to check.
geposted Fri 20 Nov 09 @ 12:26 pm
Thanks.... I will try this tonight when I get back.
geposted Fri 20 Nov 09 @ 6:24 pm
Perfect!!!!!!! Thanks!
geposted Fri 20 Nov 09 @ 11:52 pm
Hi everyone. I just got a denon dn hd2500 but i am really having trouble connecting it to my virtual dj so it will work. I got it to connect to the computer but its not working with virtual dj. can you please help me out. I could use all the help i could get. Thanks.
geposted Wed 14 Apr 10 @ 7:55 pm
im having the same problem. help!
geposted Tue 01 Jun 10 @ 9:51 pm
