I've spent quite some time searching both here and elsewhere trying to find and answer to this... Forgive me if it seems like a silly question. :-) I've been a VDJ user for about 5 minutes...and may not be searching the right terms or topics.
After you extend your desktop and drag your video window over... Is there a way to make that "full screen"? I know you can resize the window and all, but then there's still the frame around the video. ...you know, the Window's window that says "VirtualDJ Video"? Is there a way to have just the video...without the frame?
I've tried like resizing and dragging the top bar off screen, but it keeps bouncing back and showing the header... (...for lack of a better term)
Thanks for any assistance or advice anyone can offer.
geposted Sat 21 Nov 09 @ 2:02 pm
Try going to CONFIG -> Video and choosing your external display from the drop-down list (The default is (Windowed) which will show the video output in a window.)
geposted Sat 21 Nov 09 @ 3:03 pm
Well, Holy Crap! ...that was easy and worked perfectly! Thank You! (Duh...) :-)
geposted Sat 21 Nov 09 @ 3:23 pm
Chances are your windows task bar is set to the side or the top. Right click and unlock it, and move it to the original position at the bottom.
Having done that you should see the minimise, full screen, and close app icons on the top right. Click the middle one to get back to a framed window.
Then reset your windows task bar to original location.
HTHs - OL
HTHs - OL
geposted Mon 16 Aug 10 @ 3:38 pm
This is a topic from last year. If you had of read the thread you would have seen that he simply had no selected the video output and that his problem was resolved once he did.
Topic locked.
Topic locked.
geposted Mon 16 Aug 10 @ 10:40 pm
