Hi !
Here is a little update of MF5: http://fr.virtualdj.com/addons/8431/Multi_Functions_variations.html
This update brings MASTER BALANCE, GAIN RESET on double click and some little gaphic bug fixes.
Enjoy !
SQ;)
Enjoy !
SQ;)
geposted Mon 23 Nov 09 @ 7:32 am
Thanks a lot for the update, out of all the skins this one is the most professional in my opinion.
I would like to see a couple of millimetres shaved off here and there so that the record case is a little bigger, also the record button looks as if it's on when it's not with the red dot. Plus bad positioning of the button all on it's own I think it would look better set to the right next to the stop watch.
Comment field sits empty for me so a little cross to get rid of it and increase the record case would be good.
Email address in bottom left is in a terrible font and looks cheap, would look more pro if it was same as browser text. Other than that it's great and is my skin of choice. Should be default skin
ps, flashing explanation mark is bad compared to flashing circle.
geposted Mon 23 Nov 09 @ 9:07 am
