Hi guys i have a couple of questions regading the new update of vdj.
To me everything seems to run the same as the first 6.x.x even all the problems but in this version there is surpose to be improvements
1. I read that there is different timecode engines been added to this new version if so how do i change (As i cannot see the option ANYWHERE).
2. I notice there is a new option in debug which is called smooth wht does this actually do.
3. I still have the problem with the pitch slider moving up and down on its own and the bpm is constantly going up and down (I Can solve this by disableing the pitch but i want my turntables to work correctly with the software i paid alot of money for)
geposted Tue 24 Nov 09 @ 7:52 pm
1) They have made improvments on the timecodes not changed.
2) N/A(e.y.e.h.a.v.e.n.o.e.y.e.d.e.e.r.)lol
3) I think you should try Absolute timecode mode. These settings are located in the internal mixer(default skin) when scratch is selected i.e S,R,A. Also try adjusting the jog sensitivity. config>option
Hope this helps.
Hope this helps.
geposted Tue 24 Nov 09 @ 8:34 pm
So can nobody help me with this then not even the people who make the software connot tell me how to change timcode engines......
geposted Wed 25 Nov 09 @ 6:27 pm
config>sound>timecode config>vinyl>v4 cd or vinyl. This is internal. It does not change it visually.
geposted Thu 26 Nov 09 @ 1:27 am
A guide for timecode setup here
https://virtualdj.com/wiki/Timecode%20Config.html
geposted Thu 26 Nov 09 @ 7:42 am
I appologize in advanced for being the biggest noob. I currently hav numark's virtual vinyl and I want to run it with virtual dj and I now hav the latest version which I think it is6.0.3. (correct me if I'm wrong). And all of the configurations I see in these forums hav this auto config option but I do not see this. Can somebody help me straighten this out. Thank u in advanced!
geposted Thu 03 Dec 09 @ 1:42 am
