Topic: Understanding how to map
Wondering if someone on here could help me map out my Denon HC4500 ? I dont want to get complicated mapping different functions just your basic functions.
J.P Boogies mapper was awesome ,I wish he would decide to make a win7 version "HINT HINT" would be much appreciated............
Anyway for the time being I would like to attempt to map it myself ,but im completely oblivious as to how. I don´t understand any computer terminology at all guys so if you could plain English please........
Like I said just help me to understand how mapping is done and what the the hell all the funny looking wording means thanks for any help :)
geposted Sat 28 Nov 09 @ 2:57 pm
The basics are already mapped ... and there are plenty of examples in the Hardware Forum for different complex mappings.
But the basics are this ...
[deck [deck]] [sampler [slot] | effect [effectname/slot] | get] verb [param1] [param2] [blink | blinkfast] [while_pressed]
The verb is from the list of possible actions that you can assign - https://virtualdj.com/wiki/VDJscript_verbs.html
If you need to direct the verb to a specific element like a deck, sampler, or effect then some verbs can take the prefix in front of it.
examples
-- deck 1 select - selects the left deck
-- sampler 1 play_stop
-- effect "filter" active (when using effect you must use the exact name of the .dll file in the audio plug-in folder)
If a verb requires a parameter, you then follow the verb with the appropriate parameter value.
examples
-- seek -2 or seek +2
-- loop 1 while_pressed
Those are the basics ... and I would suggest to all that you spend time studying the Keyboard shortcuts as those entries can give you good insight to the basics.
JPs mapper will work fine under Windows 7. It won't however work under VDJ6 as DLL mappers are now obsolete.
