I Have some questions about the mappers
If you put a mapper in the Users\<user>\Documents\VirtualDJ\Mappers, it overrides default behaviour, but does the xml mapper file needs to have a certain name, to override the default, or is it within the xml file you need to set the "device name" value to a certain value?
If I set a certain default mapping by hand in the VDJ configuration, it works, but the key learning is not working....
geposted Sun 29 Nov 09 @ 7:59 am
