I Have some questions about the mappers
Where are the native supported mappers stored?
geposted Sun 29 Nov 09 @ 8:00 am
All the native Definition & Mapping files are stored internal in the VDJ.exe. If you want to modify one of the mappings - just load the mapper and change 1 setting - like 'loop' to 'loop 4'. If you like you can restore it to the old setting later.
After closing VDJ - the changed mapper.xml is generated in the mappers folder where you can copy it, edit or whatever you like.
(There is no access to the definition files at all. If you need some for learning how to map - download some of them from the download section.)
Greetings, Heiko
Greetings, Heiko
geposted Sun 29 Nov 09 @ 8:13 am
helped a lot, learned something new.
Thanks very much.
Thanks very much.
geposted Sun 29 Nov 09 @ 8:30 am
