I've got VDJ 6.0.3 installed and working on a dual boot set-up with Vista & Windows 7. I have been using it with Vista for months without many problems, but decided to try Windows 7. I partitioned my hard drive to install Windows 7. I now have 3 partitions: Windows Vista, Windows 7, Storage.
When using Vista I had a lot of files in my iTunes library (default location) To keep the Windows 7 installation seperate from my existing Vista setup I copied my iTunes folder to the Storage partition (b:)
My problem now is that VDJ will not store the database for the newly copied files. I have browsed to the folder location in VDj and I have set folder as a favourite, added to search db, scanned all bpm's & read all tags.
When I close VDj & start it again, the favourite folder is gone and when I find the files the are all unscanned and not seen before.
VDJ is creating a database XML file on drive b:
In the browser tab of VDJ confg, when I select drive b: to check/clean/fix it says External HardDrive : No Files
If I try to open the XML file I get:
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
Only one top level element is allowed in an XML document. Error processing resource 'file:///B:/VirtualDJ Local Database v6...
<Song FilePath="B:\iTunes\iTunes Music\Black Eyed Peas\The E.N.D\17 Mare.mp3" FileSize="7005128">
The XML file can be read with Wordpad and seems OK, all files are listed.
I tried changing iTunes in Vista to use the Drive b: location as the iTunes library, but still no joy.
All the files are DRM free
If I browse to the original files on the Vista partition I can set as favourite and it works fine.
How can I get VDJ to save the database for Drive b: and remember the favourite folder?
geposted Sun 29 Nov 09 @ 3:21 pm
Update: Just had a play and it seems that neither the Vista install or the Windows 7 i stall will save and read a database on drive b. VDJ wont save bpm info or first seen etc for any files on Drive b. Drive b is simply a partition of my internal drive
geposted Sun 29 Nov 09 @ 4:32 pm
