Hello Guys,
I connected my Pioneer cdj-400 (only one) to VDJ Atomix.. I cac see the title of the mp3 on my CDJ and can move and hear the song by moving the vinyl.. also when i press the play button of my CDJ.. the button on VDJ twinkles but it doesn't play the song!
Please help me out to solve this problem please pelase.. i can't do anythin without it!!
Thank you
Ras
Thank you
Ras
geposted Sun 29 Nov 09 @ 4:23 pm
Sounds like you having a mapping problem. What version VDJ are you using?
geposted Sun 29 Nov 09 @ 5:07 pm
It's VDJ 6.0.2...
What's the mapping problem?
geposted Sun 29 Nov 09 @ 7:33 pm
Before we go there, Make u have the 400 powered before you turn on your computer.
open vdj
Go to config>mappers
Make sure your 400 shows in the device section.
open vdj
geposted Sun 29 Nov 09 @ 9:40 pm
Sounds like your sound setup in VDJ is possibly incorrect to me? What do you have on the sound setup tab?
geposted Sun 29 Nov 09 @ 9:42 pm
- durdeesmurdee: I can see the CJ-400 on mapper's device section...
- SBDJ: On my sound setup section, I just plugged one CDJ to my laptop.. so it says Single Timecode.. and soundcard it's ASIO4All v2....
And on Timecode Config... it's VDJ v5 Vinyl....
geposted Sun 29 Nov 09 @ 10:14 pm
Turn timecode off. CDJ400 can be used as straight MIDI, no timecode needed.
geposted Sun 29 Nov 09 @ 10:19 pm
Do you have the USB button pressed and illuminated on each unit? Then make sure you have "None" selected in "Inputs", "External Mixer" in "Outputs" and "ASIO" or "2 Cards" with Pioneer CDJ400s in the dropdown.
If you don't have "ASIO" download it at www.asio4all.com. It's not absolutely necessary but I have found it to be superior to the "2 Cards" choice. I think it sounds better and is less problematic, meaning it works everytime, whereas "2 Cards" doesn't always work (in my experience using VDJ with CDJ-400s).
DJ RuDe
DJ RuDe
geposted Mon 30 Nov 09 @ 1:58 am
DJ RuDe:
Yes, I've already downloaded ASIO4All.. I just bought my Numark X6 mixer.. so I connected all of them to each other, and my CDJs to my laptop... I selected NONE for the INPUT.. and EXT MIX for OUTPUT... However still just can't 'Play' it.. even if i try clicking on software.. it doesnt play..
geposted Wed 02 Dec 09 @ 1:08 pm
You have configured ASIO4ALL haven't you?
geposted Wed 02 Dec 09 @ 3:12 pm
I just downlaoded and installed... and then it was on my VDJ.. How would I configure it?
geposted Wed 02 Dec 09 @ 4:05 pm
You need to configure it and tell it what soundcards to use I guess. I don't have it installed since I don't need it, but I'm sure someone who does will be able to tell you more precisely.
geposted Thu 03 Dec 09 @ 2:37 am
Pioneer have realesed also its ASIO driver
http://www.pioneer.se/eur/content/support/support/upgrade/CDJ400.html
geposted Thu 03 Dec 09 @ 5:33 am
Ok guys. I will check the ASIO again.. and will let you know..
Thank you all of you!
geposted Thu 03 Dec 09 @ 5:39 pm
