ok guys first time in a long time ive had trouble.almost sure its either hd or tv hardware.so hd wouldnt be recognised for ages then loaded up and worked grand for karoake.then all of a sudden crash laptop and tv screens went mad and sound stopped.ipod worked in rmx for backup.screen went all colours and laptop unresponsive had to reboot without hd and no problems and havent had probs for a long time.so guys how do i know exactly what it was what do i do to test thanks.
geposted Mon 30 Nov 09 @ 2:31 am
Hi mate
Sounds like the drive for shure. If you can get it to run at home, now would be the time for a clone/backup before it fails all together.
Stangely I have had this happen and when I re-formatted the drive it worked fine. Still bined the drive because I could not trust it.
Daz
Daz
geposted Mon 30 Nov 09 @ 3:41 am
You should copy all your data on other disk then run a tool for test, which depends on brand of hard drive you are using, usually you can find this tool on manufacturer site. If the tool says it is failing than do a low level format, if it pass it will work but if not, it's dead ;)
geposted Mon 30 Nov 09 @ 4:49 am
thought so guys and after reading previous i have it backed up 3 times lol.so how do i format and what will that actually do.went down when a bad singer was on so wasnt a hassle lol
geposted Mon 30 Nov 09 @ 12:41 pm
That depends what brand of hard drive do you have, which one is it? I think only Toshiba does not have tool for low level formating and testing but I use old Maxtor tool with the success. The tool is free, so I might upload it for you, it is quite small.
It will erase entire drive with zeros and will read back to check if it is written ok, if it is not then the drive is going to die or has some bad sectors that cannot be recovered. That kind of drive can still be used by allocating bad sectors to not be used anymore, but I rather not as it has tendency to spread ;)
geposted Mon 30 Nov 09 @ 1:35 pm
oh rite i see mate.i will be getting hd in a bit so i will see what make it is.never heard of the tools for checking.will let you know in a bit thanks.ok hd is an iomega.just plugged it into laptop and windows is checking the hd foir consistancy
geposted Tue 01 Dec 09 @ 12:45 pm
ok check done and said a few bad clusters were soeted(dont know what that means) this is the 2nd time doing this just remembered did this bout 4 months ago to.what you guys with experience of hds think
geposted Tue 01 Dec 09 @ 5:53 pm
ok hooked up hd tonight bout an hour on using automix with karaoke tracks and all working ok.deleted allmusic from hd and just left karaoke mp3s on.so did the windows checking sort my hd or any other ideas.
geposted Wed 02 Dec 09 @ 12:45 pm
ok just update used hd for 3 hours automix no probs
geposted Wed 02 Dec 09 @ 3:39 pm
Man, reading your posts are like reading abbreviated texts messages from someone in a real hurry :-)
Don't mean to offend, but I find your posts real hard to read and understand...it's hard work...honestly...
No offence buddy, but slow down, take a deep breath, and type full sentences, with some punctuation...
Like I said, I'm not trying to offend, simply trying to make my life easier...please...for me...take pity on me... :-)
Thanks mate ;-)
Thanks mate ;-)
geposted Wed 02 Dec 09 @ 7:46 pm
lol hey igma.just dont get to much time with the kids and herself wanting the net.was just trying to find out what happened at my gig last week screens went blank and music cut,but ipod played through rmx..my windows then scanned and found bad clusters.since then ive took music off left mp3 karaokes on.i then cleaned up hd and tested it last night for 3 hours(automix & clipbank laptop only)and all seemed fine
geposted Thu 03 Dec 09 @ 4:37 pm
If there are bad clusters I would do a low level format. If there are still bad ones I would not use that hd on my gig, too risky.
geposted Thu 03 Dec 09 @ 4:47 pm
will i loose my files with a low level format.and if not how will i do this mate
geposted Thu 03 Dec 09 @ 4:57 pm
I can't understand a werd this guy is saying, is this just me?
geposted Fri 04 Dec 09 @ 12:35 am
You will loose files with any kind of format!!!
Do you have a backup drive? If not, now would be a good time to get one.
I tend to buy my drives in pairs. That way I know the power supply and USB leads are identical. If I get a problem, all I need to swap is the drive.
If I were you, I wold buy a pair of new drives, transfer the contents of your existing drives to these. Then low-level format your other drive and use it as a backup.
Cheers,
Roy
geposted Fri 04 Dec 09 @ 7:00 am
Absolutely....a format will destroy everything on your drive. So, make sure you've got a good backup of the drives contents before you start.
Good luck, mate!
geposted Fri 04 Dec 09 @ 7:01 am
bryan it WORD.and will give it a go have all backed up already.just wanted to know what caused crash.i try to give as much information as i can on a problem.gadgetman good idea mate as hds are not to pricey at tho moment
geposted Fri 04 Dec 09 @ 10:24 am
guys formatted hd and no probs so maybe it was a bad lead what you tihnk
geposted Thu 10 Dec 09 @ 12:37 pm
