is there a way when doing karaoke to just play song without having to go to effects and disable clibank as i use it during singer breaks maybe a shortcut on rmx thanks guys
geposted Mon 30 Nov 09 @ 2:38 am
no answer then so take it it cant be doine was just a thought
geposted Tue 01 Dec 09 @ 5:57 pm
Not sure what you mean ;)
What do you want to do?
i would like to use my clibank between singers and not to have to go to effects and have to disable cbank before i play karaoke song ie words to screen
geposted Tue 01 Dec 09 @ 6:09 pm
you can name the effect as a keyboard shortcut
And just press a key on keyboard or midi controller to toggle between clipbank and karaoke
The action would be :
video_fx_select "ClipBank" & video_fx (turns on/off ClipBank) -> map this to a key / midi note
video_fx_select "Karaoke" & video_fx (turns on/off Karaoke) -> map this to a key / midi note
Edit : seems to lag a little.. because of the load time of clipbank - so maybe use 3 shortcuts :
video_fx_select "ClipBank" (Selects ClipBank) -> map this to a key / midi note
video_fx_select "Karaoke" (Selects Karaoke) -> map this to a key / midi note
video_fx (activates selected) -> map this to a key / midi note
geposted Tue 01 Dec 09 @ 6:34 pm
sorry greg, been busy, there are one or two skins that can be activated without going into effects that you can use if i can remember rightly.
but norways fix is just as good if you use your keyboard as a short cut.
or you can play audio only files in between and set clipbank to play when audio only is used is another option.
geposted Tue 01 Dec 09 @ 6:42 pm
normally i do tayla but would like screen to have clipbank on it stay in the mood lol with your dancing monkeys or poledancer.so because its busy when doing both just looking for easy option to switch when karaoke mp3 finished
geposted Wed 02 Dec 09 @ 12:49 pm
sent you a pm.
geposted Wed 02 Dec 09 @ 1:53 pm
