Hello
What is the difference between asio and wdm ?
what is pro and con from both ?
geposted Mon 30 Nov 09 @ 8:34 pm
ASIO is used best with time code solutions. I use my RMX in WDM mode. Reason being it works with Skype, and I use Skype for my web-radio show.
geposted Mon 30 Nov 09 @ 8:41 pm
Asio offers better latency but uses more resources. Asio is perfect for controllers where button presses can be translated to the software in a few milliseconds.
WDM generally has latencies of 30ms plus, but doesn't require specific hardware and will run on pretty much any PC. Most inbuilt PC cards are WDM or directsound.
I would suggest Asio for controller or timecode use but it will depend on your machine as to whether it runs well or not.
geposted Tue 01 Dec 09 @ 6:35 am
one thing i need from asio is my headphone PFL from rmx.
Is there a way to get pfl headphone with asio ?
geposted Tue 01 Dec 09 @ 6:40 am
WDM (Windows Driver model) is the standard used by Windows for multimedia applications (playing MP3, movies, etc). It originally allowed 1 input and 1 stereo output (remember the first SoundBlaster cards ???)
In order to bypass this limitation, Steinberg (of Cubase fame) came up with the ASIO driver:
http://en.wikipedia.org/wiki/Audio_Stream_Input/Output
In VDJ, any Multichannel soundcard (i.e. that as at least 4 outputs) will allow headphone PFL. Remember that the Rmx , and other DJ soundcards , were designed for DJ applications, so it wouldn't make sense if headphone PFL was not availalble...
geposted Tue 01 Dec 09 @ 6:53 am
