Hi all!
Does anyone know how correct the key-detection of "VirtualDJ" is compared to "Mixed in Key" Software?
I use the "Mixed in Key" software and really like it, but i want to know how good "VirtualDJ"s detection is.
can anyone please analyze some songs (especially progressive house style would be nice, because thats what i used to play) with both softwares and then post how much of them give the same results.
Thx for helping
Thx for helping
geposted Wed 02 Dec 09 @ 6:56 am
anyone who can compare the key-detection quality of "mixed in key" and "virtualDJ" ????
geposted Thu 03 Dec 09 @ 9:44 am
I have noticed that VDJ seems to think that every song is in a minor key.
I just looked in the manual and even there, they say that "most songs are in minor keys".
What's that all about?! It's obviously not the case.
geposted Thu 03 Dec 09 @ 10:05 am
Already done this on my setup. Used MIK4 and put the results into the comment field. Then in the folder in VDJ enabled the "Comment" field alongside the "Key" field. They were mainly exactly the same, except, MIK sometimes gives two keys. This was on House Music.
geposted Thu 03 Dec 09 @ 11:26 am
thx for answers.
i have another question:
mixed in key gives you the results in camelot-notation
virtualdj gives the results in ?normal? notation (dont know how it is called :-)) is that true?
if so how can i "convert" the camelot to the normal notation?
thx so far
thx so far
geposted Thu 03 Dec 09 @ 11:30 am
Most songs ARE NOT in a minor key, in fact I believe it is the reverse. Any of you who are guitar players should know this.
geposted Thu 03 Dec 09 @ 1:01 pm
The camelot notation - equivelent in VDJ is "number" on your field options. Happy Mixing!
geposted Thu 03 Dec 09 @ 2:14 pm
is it possible to scan the key of a song (in camelot notation) in VirtualDJ and then save the result in the id3 tag of the scaned mp3 files?
if so how should i do?
THX
THX
geposted Tue 02 Mar 10 @ 7:28 am
I too have the MIK, don't need it anymore because VDJ does a very good job with the Harmonic Key. Here is another question.
Does anyone use Platinum Notes, its from the same company and I'm thinkig of getting it. Some advice please.
Thanks
Thanks
geposted Tue 02 Mar 10 @ 3:52 pm
DJ in Norway wrote a good article on VDJ Harmonic Key in this forum, does anyone know where it is. I can't find it anymore.
Thanks
Thanks
geposted Tue 02 Mar 10 @ 3:55 pm
its in the recent magazine :
https://virtualdj.com/magazine/
feature about harmonic mixing there ;)
geposted Tue 02 Mar 10 @ 4:19 pm
once again:
is it somehow possible to save the determined key (in camelot notation) of a song (scanned with VirtualDJ) in the id3 tag of the scaned mp3 files.
If one uses mixed-in-key i know one can choose to save it to the mp3-file. But if one just has VirtualDJ to determine the key is it possible to save the key to the file so the key (determined in VirtualDJ) shows up in other software (meaning its stored in the id3 tag)???
THX
THX
geposted Wed 03 Mar 10 @ 4:58 am
not possible.. sorry :)
Maybe write to tag will be added back to vdj in near future
geposted Wed 03 Mar 10 @ 5:41 am
Thank you for the answers! Hope to get the feature in near releases :-)
geposted Wed 03 Mar 10 @ 3:52 pm
