Hi,
I'm looking for the directory and name of the file for VDJ where all the BPM data is stored of the mp3's I use. This in order to make a back up in case of crash or reinstallation.
Many thanks,
Johan
Many thanks,
Johan
geposted Wed 02 Dec 09 @ 11:09 am
If your music is on your C drive then you will find a file called "VirtualDJ Database vn.xml" in the "VirtualDJ" folder in your documents folder where n is the version of VDJ you are using.
For all other drives you will find this file in the root of that drive. This is the file you need to backup.
Cheers,
Roy
Cheers,
Roy
geposted Wed 02 Dec 09 @ 11:36 am
Thanks a lot Roy!
geposted Thu 03 Dec 09 @ 3:55 am
