i have just purchased some cdj 400's and run fine with virtual dj 6
but the effects on the cdj (jet, rock and wah) do not work,
instead they are the buttons for hot cue
is there anyway i can change it so i can use the effects on the cdj when using virual dj??
geposted Sat 05 Dec 09 @ 8:59 pm
No. Unfortunately they are only for use when using a CD or mp3. Not when used as a controller.
geposted Sat 05 Dec 09 @ 9:22 pm
thanks
geposted Mon 04 Jan 10 @ 7:30 pm
Hello DJ,
u can configure your CDJ400 - (jet, rock and wah) button as your favorite effects,
using "Hold" key with "Jet", "Rock" or "Wah"... u need to keep press hold and select 2nd key "Jet" number of times to select which effect u want.....
geposted Tue 02 Feb 10 @ 6:34 am
needs help!!
just recently bought a cdj400.. i have problems with the sound.. everytime i press the cue button on my cdj the sound output became distorted and if i press if again it becomes normal..
im using a
ASUS
windows vista home basic
intel core 2 dou t5850@2.16ghz 217ghz
4gig ram.
im using a
ASUS
4gig ram.
geposted Sat 13 Feb 10 @ 1:04 am
Hello
Hello DJ,
QUESTION.
Just plugged in 2 times cdj400 at VDJ. but in normal talk how can you make te FX working instead of that te FX buttons are CUE buttons.
there is no such mapper on the internet or forum. Maybe someone can write a mapper on this forum. I think its a mayor problem for everyone.
And if you have the mapping text. is also o.k. please write it in forum..
Gr
rene
Hello DJ,
QUESTION.
Gr
rene
geposted Wed 17 Mar 10 @ 4:19 am
As you are a Pro user, try going to CONFIG -> Mappers, choosing the CDJ-400 in the list, then change the mapping of the buttons to any effect or other function of your choice, e.g:
effect 'Flanger' active
For further information, please see:
http://www.virtualdj.com/wiki/VDJscript.html
http://www.virtualdj.com/wiki/VDJscript_verbs.html
http://www.virtualdj.com/wiki/VDJScript%20Examples.html
geposted Wed 17 Mar 10 @ 1:21 pm
