Hello all;
I'm currently using Virtual DJ 6.0 and I've been having an issue when recording live mixes using both turntables. For example, I can have a beat playing on Turntable 1 looping and I'll have some acapella lyrics cued on Turntable 2 ready to be manually launched. When I start turntable 2, it will all work just fine, however, when I play back the recording though, it will appear as if there is a momentary skip when starting Turntable 2 even though the actual live version was performed properly. As a workaround, I've been recording my sets with Audacity but would like to be able to use the VirtualDJ recorder if needed.
Any input is appreciated and thanks
CAT
CAT
geposted Sun 06 Dec 09 @ 10:40 pm
