Hey guys, ive recently upgraded to 6.0 and most of my shortcuts don't work. Is there anyway to fix it?
geposted Mon 07 Dec 09 @ 11:18 pm
Have you gone to config and checked the mappers?
geposted Tue 08 Dec 09 @ 4:20 am
Yes; the mapping system changed entirely (for the better) in v6, so you can no longer load shortcut/mapping files from v5. You'll have to map everything again.
geposted Tue 08 Dec 09 @ 7:29 am
ok....is there someone that could help me or even a program that could convert it to the new mappings?
geposted Tue 08 Dec 09 @ 10:28 am
Most of the mappings are probably fairly similar.
If you post them up someone may help, but I recommend learning it yourself:
https://virtualdj.com/wiki/VDJscript.html
It might also be beneficial for you to register your serial number since you've been using VDJ for long enough to have custom mappings under v5, and to then upgrade to v6...
geposted Tue 08 Dec 09 @ 10:48 am
ight cool thanx bro
geposted Tue 08 Dec 09 @ 12:30 pm
