i just started this virtual dj and i wana download plug ins but when i go to dl it says in page that "Your current licenses do not allow you to download Effects" whats the delio?
geposted Tue 08 Dec 09 @ 6:45 am
You must be registered pro user to download plugins, effects and skins.
If your using a trial version you will have to run with the ones that are there by default. Hope to see you as a pro soon. :)
geposted Tue 08 Dec 09 @ 6:57 am
Its true , I had a similar question today myself. Wondering to myself ''why can't I dl these plugins " ? Because I purchased 5.0, I was able to just login and once I did the message went away and I was able to dl the plugins. Good luck !
geposted Tue 26 Jan 10 @ 6:46 pm
hey man i need help with my virtual dj.i have a dm2 mixman and i was wondering if theres a way to sync it?or use this program with those tables.
geposted Sun 02 May 10 @ 2:40 pm
