Hi everyone.
So I'm trying to get this stuff working(so far on demo), to try and figure if I should take the leap from Traktor to VirtualDJ. I ran into some issues though. The controller acts very differently in VirtualDJ compared to Traktor(may not be a bug), so there's some stuff that I can't really figure out.
First:
In Traktor, you can enable the "search" and the "scratch" buttons at the same time to enable pitch bend. Is this disabled in VirtualDJ?
I will reply this topic when i find more bugs/things that I can't figure ;)
Hope you can help.
First:
Hope you can help.
geposted Wed 09 Dec 09 @ 2:21 am
VirtualDJ is not Traktor, so it will not be exactly the same. Buttons on controllers are mapped to the closest suitable function in VirtualDJ, however you can change them if you wish to suit your own preferences via CONFIG -> Mappers
Pressing the SCRATCH button toggles between scratch (Vinyl) and pitch bend (CD) modes. The button LED is on when in scratch mode.
Likewise, pressing SEARCH toggles the controller into search mode. Pressing it again turns of search mode.
geposted Wed 09 Dec 09 @ 4:47 pm
