thsi is why i waited and waited. i update to 6 and can't get the timecode cd to config at all. i'm using a korg zero 4 mixer for sound card etc. i had NO problems in cue 5 with tc control. i get a straight line in the window for tc config and 0% quality. i am using the vdj cd code form this site and have tried both vdj 4 and 5 in the config. i even went to my ssl cd and used the ssl setting and that didn't work. i tried new cables and it didn't change anything. i have to play tonight so i need this corrected asap. any help would be great.
geposted Thu 10 Dec 09 @ 12:04 pm
now its jumping from 0 to 100% then back down but still striaght line in the window that should have a circle. what changed so much from 5 to 6?
geposted Thu 10 Dec 09 @ 12:29 pm
ok so after installing cue 5 and opening it under a dif shortcut etc it now works in cue 6? i don't get what happened i didn't change any settings as i was in cue 5. weird.
geposted Thu 10 Dec 09 @ 1:35 pm
