guys can you delete service pack 2(s) on system if i already have service pack 3.or will it affect my laptop for vdj.im using windows xp
geposted Thu 10 Dec 09 @ 12:52 pm
The newer drivers in SP3 override the SP2 ones, so you can't "delete" a service pack.
VDJ runs fine on XP service pack 3.
Give us some details of what you are actually trying to achieve with this?
geposted Thu 10 Dec 09 @ 12:59 pm
just basically going through my system(add/remove) to see what i need and dont need.dont want to do anything bad as running smooth at the mo
geposted Thu 10 Dec 09 @ 1:06 pm
If you just installed sp3 you can perform a system restore back to SP2. I had to since my pc was totally unusable with sp3, to the point it was almost a dead laptop with a pretty wallpaper.
But other then a restore i dont believe you can uninstall sp3, it runs good for most just not on my machine for some reason.
geposted Thu 10 Dec 09 @ 1:39 pm
If it's running fine then just leave as is.
geposted Thu 10 Dec 09 @ 1:48 pm
yeh will do mate.just learning as i go
geposted Sun 13 Dec 09 @ 4:12 am
Im looking at he same thing. In my add and remove, I have 3 sps. Can you remove previous sps i.e 1 and 2 without problem?
geposted Sun 13 Dec 09 @ 4:15 am
lol knew ther was someone else like me out there.as i said i will leave it as vdj working well
geposted Sun 13 Dec 09 @ 4:28 am
My advice is to leave them alone. All a service pack does is update the windows system files to a newer version if required. The older versions are then stored away should you need to roll a driver back.
I guess if you did try to uninstall a service pack it would fall over anyway .... if you are not desperate for hard drive space then don't touch. Simple as that.
geposted Sun 13 Dec 09 @ 6:02 am
and thus ends thread.thank kradcliffe mate
geposted Sun 13 Dec 09 @ 6:10 am
Yup leave it alone.
geposted Sun 13 Dec 09 @ 6:13 am
