Would this laptop run VDJ on MAX qulitly setting with no hicups?
Macbook Pro 15inch
core2 duo 3GHz
4GB DDR3 RAM
256GB Solid State HHD
512 Nvidia Graphics
I have a HP Pavilion dv5t-1100 laptop.
Core2 Duo 2.0 GHz
4 GB DDR2 SDRAM
Vista 64bit OS
MAYA44 USB Souncard with latest ASIO Drivers.
When i use my Time Code Vinyl on VDJ the sound qulity is terrible. it sound awful.
Im by no means a noob at TCV and i have 100% signal qulity on time codes.
Is there anything anyone can think of that may solve this bad qulity sound. pops, hickups, random jumping to diff parts of songs. Also if i play one record and quickly rewind the other.. the music stops playing.
Is it just this laptop that cannot handle ASIO/TCV?
Many Thanks :O)
Macbook Pro 15inch
core2 duo 3GHz
4GB DDR3 RAM
512 Nvidia Graphics
Core2 Duo 2.0 GHz
4 GB DDR2 SDRAM
Vista 64bit OS
Many Thanks :O)
geposted Thu 10 Dec 09 @ 2:30 pm
the bad quality is due to the vinyl you are selecting in the vinyl configuration try differents vinyls like virtual vinyl old version, if that no fix the problem then put the latency at 17 ms and the bad sound quality will go away.
geposted Thu 10 Dec 09 @ 11:20 pm
Thanks..
have tried everything. and nothing helps..
Think its just this laptop.. 320kbs MP3's sound like crappy AM Radio when using time code vinyl.
Apple Mac i hear is the shizzle for DJ'n... any opinions here?
geposted Sat 12 Dec 09 @ 1:11 pm
Keylock on ?
geposted Sat 12 Dec 09 @ 1:16 pm
