Hi
Is it possible to have to installations of VDJ / VV on one machine i.e. v5 and v6?
Thanks
Jon
Thanks
Jon
geposted Fri 11 Dec 09 @ 7:53 am
Yes, you can do this by renaming the executable, e.g:
Install VDJ v5.2
Go to C:\Program Files\VirtualDJ and rename virtualdj.exe to virtualdj521.exe and make a shortcut to it.
Install VDJ v6.0.4
Now you can run v5.2.1 using the shortcut you made above and v6 by using the normal VirtualDJ shortcut.
Install VDJ v5.2
Install VDJ v6.0.4
geposted Fri 11 Dec 09 @ 11:38 am
