so besides the crash report that know one seems to know a reason for how about this one. last night first time out with cue 6 and i noticed a few of my transitions where not working and when i went to load a sample into the sample bank i went to the folder containing my drops an NONE even showed up. so i went in windows explorer and they are all just sitting there waiting to be used but don't show up in the folder view inside CUE 6. never had this problem with other versions. so anyone have ideas?
geposted Fri 11 Dec 09 @ 2:52 pm
check to see if hard drive is there...if so, see if the drive letter changed...I hope this helps
geposted Fri 11 Dec 09 @ 11:12 pm
yes drive is there i accessed the file svia windows explorer. i dont know what happened but last night i gave 6 a try again in the club and this time i was able to load samples and see the files for the sampler etc.
geposted Sat 12 Dec 09 @ 10:42 am
I have had this happen aswell, but only once?? Strange.
geposted Sun 13 Dec 09 @ 2:45 am
I also could´nt load any new downloaded samples onto VDJ. I made various atempts to install different ones and no difference at all. Did a registry cleanup reinstalled new fresh downloads and nothing again ,oh well did´nt care much about it because I really dont even use that much!
So , I put it off to the back burner just thought maybe this was random but , I guess not good luck :)
geposted Sun 13 Dec 09 @ 4:06 pm
If you change the extension from .vdj to .mp3 they will play fine.
geposted Sun 13 Dec 09 @ 4:46 pm
i'm not talking about files from the sampler folder. i have a folder of mp3's that has my drops in it. when you put it in cue/vdj then it saves the .vdj file those showed up fine. it was the actual mp3 files that didn't show up.
geposted Mon 14 Dec 09 @ 9:12 am
