Is it better to set the deck gain at 50% or each track at 0 gain?
geposted Sun 13 Dec 09 @ 6:41 pm
it just depends on your A) song volume setting, B) your over all mix, C) volume of prev played song..
geposted Mon 14 Dec 09 @ 4:19 pm
I mainly seeking gain advice for optimal recording.
When I am recording a mix on my RMX, I have each deck volume maxed as well as the master volume.
The respective gains for each track used are not homogeneous, so I am wondering if playing everything at 50% gain is ideal?
geposted Tue 15 Dec 09 @ 9:17 am
if in recording i wouldnt suggest maxing, could cause major distortion during playback..
geposted Tue 15 Dec 09 @ 12:17 pm
thanks for the feedback so far... what volume level would you recommend when recording?
geposted Tue 15 Dec 09 @ 12:35 pm
i would say do a sample
geposted Tue 15 Dec 09 @ 1:05 pm
48% - 50% overall gain seems to be working fine after listening to a few recorded samples
geposted Thu 17 Dec 09 @ 5:46 am
