i just starting using one of these cards. it is very loud and sounds crystal clear until you adjust the pitch, then the sound seems to break up a a bit. i do have keylock on, but i never noticed a break up with the sl 1 box i was using prior. any suggestions on how to use the advanced master tempo. (always left all settings on performance with sl 1 card). the audio 2 seems so much better than the sl 1 except for the pitch adjust. anyone else have this issue with the other ni cards. i was going to get the audio 4 but was told the audio 2 was just as good if u don't need timecodes
geposted Mon 14 Dec 09 @ 4:33 pm
