Once you add your HD to the data Base.. you shouldn't have to add it each time you re-start the computer and open VDJ should you?
Thanks for the info...
geposted Wed 16 Dec 09 @ 12:08 pm
no mate as vdj database(found in my documents) saves all your data ect.one hint i will give from experience is if you are going to change song names ect or move songs to different folder do it within vdj so your database holds the info.otherwise you will have files/folders not in your search,
geposted Wed 16 Dec 09 @ 12:19 pm
Mahalo!
geposted Thu 17 Dec 09 @ 10:09 pm
