helo just a quick question. Using virtual dj pro i know that you can buy the virtual timecode and run vinyl that way through the mk2 consol but if i wanted to use normal vinyls and then still run through the mixer and virtual dj would this be possible?.
geposted Thu 17 Dec 09 @ 11:53 am
Yes, you can do this by assigning a keyboard or MIDI shortcut to the action timecode_bypass
When active, this will allow you to play normal vinyl.
NOTE: This should not be used as an emergency backup - It will only function with your computer and VirtualDJ running.
geposted Thu 17 Dec 09 @ 12:22 pm
ok so how do i do that. and thanks for the reply
geposted Fri 18 Dec 09 @ 9:04 am
