I just installed theVDJ v6 and using MixLab Skin and everything working fine except that there is one big problem/headache that I just could not figure out how to fix this, maybe you guys can help. Here 's the situation:
-I load a track to Deck 1 and start playback, then loading a track to Deck 2 and SYNC it..then I started mixing/blending the mix. When Deck 1's track finished, I ejected the track and load a new one. Here is the problem: As soon as i started loading the track into Deck 1, the BPM of Deck 2 automatically adjusted to the BPM of the new track that was loaded into Deck 1 hence causing sound drift. This is happened quite a few times and seem like only when I load a track into Deck 1 this happened but not on Deck 2. Please help, anyones have this problem? thanks for your inputs
geposted Fri 18 Dec 09 @ 6:57 am
turn off auto syn and key lock then you should be fine
geposted Fri 18 Dec 09 @ 4:37 pm
