Topic: Video Registry Tool Question
1. I would like to know if it's still necessary to use the registry tool for my nVidia 8600 GT Video card drivers.
2. I've downloaded and install the new drivers for my video card which is ver.195.62_notebook_winxp_32bit_international_whql.exe.
3. If it's still recommended to use this tool, there is no instructions on how to use it, all the options on the program is making me a little nerves since I don't know what or how to apply changes on any of these options and it is a Registry tool so, I'm looking for a little help here before I use it.
T9500 Duo, 4Gig Mem, nVidia 8600 GT 512 Vid, Xpro OS, VDJ 5.2.1
Thank You
Joey...
geposted Fri 18 Dec 09 @ 1:54 pm
Can anyone help me with this, I put in a ticket and haven't got a reply yet.
I have two shows tonight and three tomorrow would like to fix this ASAP.
Any help is appreciated.
Thank You
Joey...
The Registry Tool option is only a check box ... what instructions do you need ??
IF you have the video freezes then you check the nVidia fix in the tool and see if the video doesn't freeze. If the box is checked and since you just upgraded your drivers, then maybe uncheck the option and see if you still have issues.
Also, not that I would suggest making changes for a show .. but why have you not gone to v6 ?
do u have to run the registry tool everytime u use vdj?
No, the settings are stored permanently until changed.
cool thnx
Sorry cstoll forgot to click the bell and thanks for your reply.
Well since I posted I've upgraded to 6.5 and though there was an improment in the upgrade I still had some issues with the video, but I found an alternate solution with two programs that I started to use which has improved my video issues to the point of Happiness!!!
The first thing I use was a Game Booter Program that turns off background services not vital for VDJ operations., Link:http://www.iobit.com/gamebooster.html?Str=download
The second thing is a program to manage memory " Momory Improve Master" which made the difference., Link:http://www.memoryimprovemaster.com/memory_improve/index.htm
One of your support staff answered my RFI on the register tool and I downloaded the right one.
I haven't used the registry tool yet, but will it hurt if I do?
Thank you & Happy new year.
Joey....
The registry tool won't hurt anything permanently.
If you change a setting, take a note of it. If it doesn't work out, shut down VDJ, change the setting back then restart.
Hi Kradcliffe
I've never use the VDJ registry toll, does it give you a reading of what is in the registry key to be edited and what is going to be changed?
The reason I ask is because if I need to revert back to the original key then I would need to copy or somehow backup that key before editing.
Is there a backup option in the registry tool and if not, what would be the procedure to accomplish this task before editing.
Thank You
Joey...
acw_dj wrote :
To see all info about some params in Registry tool you could go here:
https://virtualdj.com/wiki/RegistryValues.html
That's for the reply acw dj, but the link you supplied doesn't answer the specifics of my question which is; if I need to revert back to the original key then I would need to copy or somehow backup that key before editing.
What would be the procedure to accomplish this task before editing.
Thank You
Joey...
Joey..Hi! i've downloaded the Game Booster,and i allready have the memory improvment master, wondering would'nt this program takeup memory space when running along Vdj ? and exactly how does it work ?
Hi theracker510
I be honest I don't know if I really need the registry tool to improve what I was able to obtain using the two programs 1= Memory Improve Master and 2= Game Booster.
I put in a ticket a while back and they still recommend using it, I guess it's something in the nVidia drivers that don't agree with the VDJ process of Videos or something?
I'm still trying to get an answer on the specifics of the key change the registry tool makes. so I know what to do in case I have to revert back to the original key specs.
Hope they can answer my request soon.
How's been your experience with the programs in your VDJ Video performance?
Joey...
