So I just got my Maya 44 yesterday & I hooked it all up. But I'm having this issue where the sound is all distorted, skips, & speeds up & slows down. This kinda shows my issue. I'm not sure if its my Denon-S1000's or if its my Mixer ( DMXM09) or if its Virtual Dj, or the laptop itself. I know some of you are going to say, "Just get Serato." But @ this point in my life I can't afford it. Any Ideas on what the issue is? The quality is @ 0% & its suppose to be @ 100%. Sorry for the quality of the video, I took it with my iphone.
Here is the first part:
http://www.youtube.com/watch?v=uy_rmKDjwyU&feature=player_embedded
Part 2: This is the best Video of the issue.
http://www.youtube.com/watch?v=bpRgqAzNhLc&feature=player_embedded
Part 3: This shows my settings. My quality is @ 0%. It should be 100%. Please help me out.
http://www.youtube.com/watch?v=nao2_68_SSE&feature=player_embedded
geposted Fri 18 Dec 09 @ 5:05 pm
Ok, #1. Persons on this forum would never slate vdj to go with serato.#2 Serato is just another tool for dj's since it uses the same concept as vdj with timecodes mp3's etc.... No one is better than the other just one may be more suited for someone and not the other. So to start with I hope you plan on purchasing vdj soon as a pro user. With version 6.0.4 the pitch tends to oscillate alot which is being fixed at the moment and almost ready for Christmas . To disable the pitch because of the timecodes click on config>Sound setup>Timecode config>Debug> and tick disable pitch also remove the tick from ClearSound depending on your setup. The next thing is concerning the 0% of the timecode vinyls you may want to check if your gains are high enough. I know there are tons of persons on this site that use the maya 44,get 0% signal and still control vdj perfectly,so someone else may want to answer that. Take care my friend and respond if it works.
geposted Fri 18 Dec 09 @ 9:49 pm
