Im trying to use the auto feature with virtual dj 6 pro, but it's only mixing on one deck... can someone tell me how to configure my settings so that it will automix on both decks
geposted Fri 18 Dec 09 @ 6:47 pm
Interested in finding this out also
geposted Fri 18 Dec 09 @ 9:33 pm
No way to do it guys! Automix works on one deck only, designed that way...
Why would you want it any other way? With Automixing on one deck, this leaves you a free deck to do whatever you like!
geposted Fri 18 Dec 09 @ 11:00 pm
You can use automix_dualdeck but be warned that it is deprecated.
geposted Fri 18 Dec 09 @ 11:15 pm
i was using basic before upgrading to pro and during auto mix the basic was useing both decks. while the one deck was playing the other deck would load the next song in my play list and give me the option to mix/bleen the two song by just pushing the auto mix button... it was also ajust the pitch of the waiting song with the one that was already playing... I liked these options!!!
geposted Sat 19 Dec 09 @ 1:10 am
I like the idea that VDJ went to the one deck automix option. You can do the same thing on one deck as you used to be able to do on 2 decks. The best part about automixing on one deck is you can listen to other songs on the open deck and then drop them into the playlist for automix. You can also crossfade over to the open deck anytime you want to play that one. Then just pause the automix deck and play again when you want to go back to automix. I tend to play samples of songs on the open deck into the automix using the crossfader like giving a hint of the next song coming up. It took me awhile to get use to the single automix deck but I very much like it now. This way there is no way you will ever miss a crossfade to the next song.
Gary
Gary
geposted Sat 19 Dec 09 @ 10:56 pm
Anytime you want to mix early, just double click any song on your auto mix list, and it will blend the new song in immediately or as stated before, just turn it off and mix the song yourself, and restart auto mix. Just make sure you delete all of the songs that have played from the list, or have the song you want to mix from in the auto mix list where you want it to start.
geposted Fri 22 Jan 10 @ 12:19 am
you still have these options with single deck automix..
you can adjust each song individually on how it mixes and its intro outro points..
right click on the "bpm" button on the screen and that window will bring you to the automix options for that song..
geposted Fri 22 Jan 10 @ 11:11 am
Love this feature...!
One of the many reason I moved fro PCDJ to VDJ...!
Great job VDJ!
Scott
Great job VDJ!
Scott
geposted Fri 22 Jan 10 @ 2:34 pm
Welcome Scott
Thought you were never going to make it.
You'll find many people here you know I'm sure.
geposted Sat 23 Jan 10 @ 6:05 am
you cant auto mix on both decks at the same time.
geposted Mon 22 Mar 10 @ 5:37 pm
Pptt back to PCDJ then i guess.
geposted Sat 05 Jun 10 @ 1:49 pm
Thanks for the useful post, but why?
geposted Sat 05 Jun 10 @ 8:04 pm
