I saw these at Frys the other day, wondering if it would really make a difference using them or not. It says can go as fast as 1200 Mbps data transfer rate.
Anyone using these? would it affect the power output if using multiple devices ie external hardrive, soundcard, midi controller?
http://www.monstercable.com/productdisplay.asp?pin=4704
geposted Sat 19 Dec 09 @ 3:06 pm
I would say "Yes" because there better quality than a standard lead, better quality usually means better performance.
geposted Sat 19 Dec 09 @ 4:19 pm
If you are using USB 2.0 it is a waste since it is limited to 480 Mbps. USB 3.0 will support up to 4.8 Gbps when the devices become available. They will also require new cables.
geposted Sat 19 Dec 09 @ 10:52 pm
$30 for a 3ft cable.. the usual Monster Crock..
Honestly, USB doe snot require this nonsense, just use your average normal priced cables.. no problem..
It's the same nonsense they try to sell you on their speaker and signal cables..
Just say no!
Just say no!
geposted Sun 20 Dec 09 @ 11:25 am
Sam's Club....$6.99 for 2 6ft cables!
geposted Mon 21 Dec 09 @ 9:26 pm
