hey im having some issues with my denon hc 4500. I have 32 bit vista. The denon seems to be working as a soundcard, but vdj isn't picking it up as a controller.
Thanks in advance for your help.
edit: i installed the drivers + firmware
geposted Sat 19 Dec 09 @ 9:33 pm
I too use the HC4500 controller and love it. Go to downloads and find the jpboggus mapper for the HC4500. This is a great driver/mapper and works well for this controller. Good Luck....
geposted Tue 29 Dec 09 @ 8:56 pm
Are you using the latest trial version? The JP Boggis mapper is only downloadable by registered users who have purchased VDJ and will only work in VDJ 5.2, In version 6 go config, mappers and scan for new devices. If the HC4500is connected properly it will detect the device and you can change the default mapping to suit using VDJ script.
geposted Wed 30 Dec 09 @ 2:01 am
Can anyone help i have just purchased dn-hc4500 and ive connected it to vdj 6.0.5 but nothing is happening can anyone help me as to what i need to do im usind windows xp
kind regards
Stuart
kind regards
Stuart
geposted Wed 07 Apr 10 @ 12:21 pm
