After installing the new version of VDJ (2.1) I have following problem.
After starting VDJ it Freezes periodically for a short time (about half a second). This happens all 5 seconds. Disabling the video function will not change the problem.
Hardware:
1200 MHz
512MB Ram
Can someone help me?
Hardware:
1200 MHz
512MB Ram
geposted Mon 09 May 05 @ 11:53 am
There are a cpl of features that you can turn off for smoother use, at "slower" pc
1. Turn OFF "read idtag"
2. Try changing "reactivitiy" to normal (its put on high as default now.. Normal is what VDJ was before 2.1, and might be better for you)
geposted Mon 09 May 05 @ 12:18 pm
I really think your processor is too slow to have reactivity=fast
In fact, you can change the value of "reactivity" in the windows registry. Previous version of VDJ had a value of 30
fast=10, medium=40, slow=100
geposted Mon 09 May 05 @ 12:27 pm
You can change in Virtual DJ settings also
Go to the "general" tab in virtual dj settings, locate "reactivity" and change to normal
geposted Mon 09 May 05 @ 1:51 pm
Changing the reactivity options takes no effect. It always freezes.
Changing other option which could take performance to disabled also takes no effect.
Task Manager switches in that moment up to 80% cpu usage, but it shows no program, which takes that cpu usage, because the display freezes, too.
I´ve looked into my system. I don´t have a 1200MHz cpu, I still have a 2GHz cpu.
geposted Tue 10 May 05 @ 9:00 am
what about the time vdj is not running ?
did you try microsoft antispyware and spybot search&destroy
if not download and UPDATE it (www.microsoft.com and www.spybot.info)
I think in spybot you can see all processes
What operating system you have ?
geposted Tue 10 May 05 @ 11:23 am
I have checked it with spybot. No spyware on my system. When VDJ is down, the cpu usage is between 1% and 2%
geposted Tue 10 May 05 @ 4:13 pm
Well it's definately not the configuration. On my home PC with 1 Ghz & 384 Mb RAM the sound is smooth as silk (and minimum config is even lower than that..). I'm sorry, but I have no solution for your problem :/
Did 2.06 run ok?
erXon
Did 2.06 run ok?
erXon
geposted Tue 10 May 05 @ 6:54 pm
Yes 2.06 run without problems. I have installed 2.06 again and it works without any problems. Then back to 2.1 and it freezes.
geposted Wed 11 May 05 @ 8:03 am
I have Pentium III 550~616MHz, 384MB RAM and "reactivity=fast" working pretty good. ;) I think it's under bellow if we talking about minimum configuration and still works fine (without video mixing of course). ;D
geposted Thu 12 May 05 @ 11:31 pm
