Still can't type in the search engine without getting choppy audio, still can't navigate within the config menu without sound output settings changing. I guess I can use 6.5.0 if I don't ever plan to open the config menu or conduct a search for a song. I'm quite disappointed.
One improvement I did notice right off the bat is the timecode engine and keylock is very good now, but with the forementioned glitches I still consider this version unusable.
geposted Sun 20 Dec 09 @ 11:34 am
I have same problem but when I switch to just one deck it fixes the problem. Thing is I want to use two deck :( DOnt know how to fix
geposted Fri 12 Mar 10 @ 5:01 pm
do you have the key lock on??? if so.....try it with the key lock (Off)
geposted Mon 15 Mar 10 @ 8:30 pm
