Hi,
Im planning to connect my RMX to my hi-fi and use the hi-fi as an amp. On the back of the hi-fi are connectors like those circled. Can anyone tell me what type of lead i will need? Or will it come with the RMX?
http://tinypic.com/r/w9td9w/6
Thanks
Thanks
geposted Mon 21 Dec 09 @ 5:44 am
you will need rca to rca leads, can't remember if they come with the rmx or not but are readily available and quite cheap.
geposted Mon 21 Dec 09 @ 6:07 am
You can go for a cheap pair of cables like these: http://www.maplin.co.uk/Module.aspx?ModuleNo=1020
Or you can spend a few quid extra and get a better quality lead: http://www.maplin.co.uk/Module.aspx?ModuleNo=220203
geposted Mon 21 Dec 09 @ 6:32 am
Thanks a lot for the help!
geposted Mon 21 Dec 09 @ 6:43 am
dude, have you never used phono leads before??? lol.. sorry i just find it strange that you dj and have never come across rca phono cables...
geposted Mon 21 Dec 09 @ 5:16 pm
