was reading up on how to set up dn hc 4500 with vdj and it said for vista users to change jog trans to 10ms, how do i do this? thx in advance, peace!!
geposted Mon 21 Dec 09 @ 7:52 pm
1. Preset mode
Press and hold in the PRESET button for at least 1 second to enter the preset mode. w
Use the PARAMETERS knob to select the preset item. e
Select the item and press the PARAMETERS knob to set the preset item to be changed. r
Next, turn the PARAMETERS knob. The preset data is selected. t Select the data and press the PARAMETERS knob to set the preset data to be changed. y
To make multiple presettings, repeat steps w ~ t. u The preset mode is turned off when the PRESET button is pressed.
2. Preset items and data
The “*” mark next to the data indicates the default value.
(1) USB Mode Sel: HC4500 MIDI* Selects the USB communications mode. The DN-HC4500 uses unique MIDI specifications.
(2) CD Model Sel: DN-D4500* / DN-D4000 Select the name of the model to be connected to the DRIVE terminal and controlled. The BU4500 is the same as the DN-D4500’s drive, so the PRESET setting is “DN-D4500”.
(3) Audio Fs Sel: 44.1k* / 48k / 96k / Auto
(4) UnitNo.Set:1to15/ALL* Sets the device’s unit number. For example, when two devices are connected to a PC, set one device to “No. 2” or the like.
(5) MIDI CH Set: 1&2* / 3&4 / 5&6 Sets the MIDI channel.
(6) JOG Pulse Sel: 1480* / 740 / 555 / 370 count/cycle Selects the number of pulses output per one revolution of the jog wheel.
(7) FaderIn Mode: 1-PLAY/CUE / 2-PLAY / CUE
(8) X-CONT XFD: OFF / ON* Sets whether to enable or disable X-control input signal cross fader input.
(9) Preset Init.: Set all the preset data back to the factory defaults. q To clear the PRESET data, push the PARAMETERS knob.
“Preset Init” flashes on the character display. w Push the PARAMETERS knob again.
“Push to ExeØ” is displayed on the character display. e Push the PARAMETERS knob again.
“OK to CHANGE?Ø” is displayed on the character display. r Once clearing is completed, “Completed!” is displayed.
NOTE:
If the setting made at the “CD Mode Sel” presetting does not correspond to what is actually connected, the unit may not operate properly.
8
44.1 kHz:
48 kHz: 96 kHz: AUTO:
The sampling frequency (Fs) is fixed at 44.1 kHz, regardless of the data sent from the PC. The sampling frequency (Fs) is fixed at 48 kHz, regardless of the data sent from the PC. The sampling frequency (Fs) is fixed at 96 kHz, regardless of the data sent from the PC. The sampling frequency (Fs) switches automatically according to the data sent from the PC.
q To set “Fs”, press PARAMETERS. “OK to CHANGE?Ø” is displayed on the character display.
w Push the PARAMETERS knob again. e After the sampling frequency is changed, “Audio Fs Sel” is displayed.
NOTE:
8
44.1 kHz:
geposted Tue 22 Dec 09 @ 2:35 am
