Hey for all my timecode vinyl users..
Everyone has to adjust pitch to beatmatch but..
Can you adjust the pitch of the turntable without playing the record?
Will VDJ still know that you are adjusting the pitch? Or does the record have to PLAY, before you can adjust the pitch.
And does it show on the BPM counter that you are adjusting the pitch?
Thanks!!!
Thanks!!!
geposted Tue 22 Dec 09 @ 10:50 pm
The record has to be playing; if the record isn't moving then no timecode signal is being sent and VDJ has no way of knowing what is happening.
The BPM changes, yes.
geposted Tue 22 Dec 09 @ 11:22 pm
Another way of putting it if the turntable is off you are not adjusting anything you are just moving a potentiometer.
geposted Tue 22 Dec 09 @ 11:48 pm
Thanks a lot guys I appreciate it
geposted Wed 23 Dec 09 @ 9:51 am
I use virtual dj 5.0 to play my music, not really to mix songs.
If it is in AUTOMIX mode, it plays the listed tracks after an other. But at the AUTOMIX POINT it switches to the next track, and that is not the end of the track
Question 1 is > can I move the AUTOMIX POINT to the end of the song. ?
Question 2 is > can I insert a pause of 1 or 2 seconds between each song. ?
Regards Walter
Regards Walter
geposted Wed 23 Dec 09 @ 10:27 am
you can do that with winamp.
geposted Wed 23 Dec 09 @ 10:31 am
