Hello !
Sorry for my english but the german forum don`t help !
I have connect the radius with usb to laptop and load the mapper on VDJ !
But it doesn`t work !
Only for sec. and then the player do nothing!
What is the problem ??
I hope anybody can Help!
Thanks
Thanks
geposted Wed 23 Dec 09 @ 12:10 pm
You should not have to load any mappers from the site if you are using 6.0.4 or 6.0.5 - the definition and mapping are already there.
What operating system are you using ? Vista or Windows 7 ?
geposted Wed 23 Dec 09 @ 1:56 pm
I use Window 7 64Bit !
IBM Laptop Intel Duo Core 2,0GhZ , 4 GB Ram
OK I delete the mapper but I think I can`t find them in config - mapper !
I try It ! I give an answer !
Thank`s !!!!!
Thank`s !!!!!
geposted Wed 23 Dec 09 @ 6:13 pm
