Is it possible to have effect crossfader somehow in VDJ?
I would like to make dry/wet crossfader and crusher effect crossfader.
I tried to assign this script to my controller crossfader:
crossfader & deck 1 effect slider 1 & deck 2 effect slider 1
I also have other function that activates same effect on both decks.
Now if I activate same effect on both decks, crossfader almost work except for that the deck 2 slder value should be inverted.
Is it possible to invert the value?
Thanks!
Thanks!
geposted Wed 23 Dec 09 @ 12:40 pm
param_invert will invert the value, but if you are using the same effect on both decks, what you are trying to do will not be possible - Effects do not have separate independent sliders for each deck (The wet/dry knobs control sliders #1 and #2 of the selected effect.)
geposted Wed 23 Dec 09 @ 3:01 pm
