I have a new Akai llpd8 vdj 6.0.4 doesnt seem to recognize the device. In miditrace it shows up as "Usb Audio Device" I have tried using the drivername= but still doesnt work. I also tried using the syexid= that the device returned which was "F0 7E 01 06 02 47 75 00 19 00 00 00 66 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 " that didnt work either. Does anyone have any suggestions?
The only devices that show up in the mappers section is my bcd, keyboard and simple midi wrapper.
THis is an awesome device compared to the Nanopad, and i wouild like to start using it as soon as possible.
geposted Thu 24 Dec 09 @ 10:58 am
USB Audio Device is a generic name assigned by Windows XP and will not work.
If it answers to SysExID, add the response to the controller definition with the spaces removed, e.g:
sysexid="F07E01060247750019000000667F0000000000000000000000000000000000000000F7"
geposted Thu 24 Dec 09 @ 11:46 am
I tried that already doesnt recognoze it even then. This is the first piece of hardware i havent been able to get working.
geposted Fri 25 Dec 09 @ 11:24 am
ok I have a mapper and device file now that seems to recognize the lpd8 but still the buttons dont work. here are the contents of the files"
Device:
<device name="Akai Lpd8" author="Slimfams" type="MIDI" sysexid="F07E??06024775001900000066000000000000000000000000000000000000000000F7">
<button cc="0x00" name="PC Pad1" />
<button cc="0x01" name="PC Pad2" />
<button cc="0x02" name="PC Pad3" />
<button cc="0x03" name="PC Pad4" />
</device>
Mapper:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="Akai Lpd8" author="Slimfams" description="Akai Lpd8" version="605" date="25/12/2009">
<map value="PC Pad1" action="play_stutter" />
<map value="PC Pad2" action="play_stutter" />
<map value="PC Pad3" action="unload" />
<map value="PC Pad4" action="unload" />
</mapper>
Any suggestions would be helpful
Device:
</device>
Mapper:
</mapper>
geposted Fri 25 Dec 09 @ 12:30 pm
Buttons on a controller will usually send a MIDI note, so you would normally need:
<button note="0x00" name="PC Pad1" />
If the controller does actually send CC's for buttons, then you would need both cc="0xNN" and value="value", where value is the value the button sends when it's pressed down (You can find this with MIDItrace), e.g:
<button cc="0x00" value="0xFF" name="PC Pad1" />
geposted Fri 25 Dec 09 @ 12:41 pm
I am not very familiar with miditrace, i usually use midi ox. there are 3 types of command it sends here is a sample of the data from miditrace
pad:
90 00 2A 00
cc:
B0 00 00 00
prog change:
C0 00 00 00
I am assuming that the pad is a note, the cc is just that, not sure what the pro change does. No matter what I seem to do VDJ doesnt respond to the pads at all.
pad:
90 00 2A 00
cc:
B0 00 00 00
prog change:
C0 00 00 00
geposted Sat 26 Dec 09 @ 12:05 pm
Damnit, my whole problem all along was a cheap usb hub. Time to go find a good one. Thanks for all the help. Ill post the mapper when im done with it.
geposted Sat 26 Dec 09 @ 1:14 pm
where do I upload the files to now that I am done?
geposted Sat 26 Dec 09 @ 2:52 pm
You can submit it to the Tools section once it's finished:
https://virtualdj.com/addons/action/submit.html?type=tools
geposted Sun 27 Dec 09 @ 7:17 pm
hi, have just brought the akai lpd8 and i want to use it to control my effects, does any1 have a mapper that works and instructions on how to set it up, i have tryed the one you can download from the tools menue but im still haveing no luck!!
any help would be really appriecated!!
thanks
tom
thanks
tom
geposted Wed 31 Mar 10 @ 5:22 pm
Help me.
I have a numark mixtrack and akai lpd8.I don't know setup it with vdj.
pleas give me mapper for it.
help.....................................
geposted Tue 01 Nov 11 @ 8:28 pm
Setup is only possible with VirtualDJ PRO Full to run multiple controller devices.
You can purchase it using the BUY page - https://virtualdj.com/buy/
And, with the PRO license you will receive access to the download area; where there are some mappings available for the LPD8.
** Please do not ask for people to download and 'give you' the mapping. It will quickly get you 'Blocked' from our forums and is not a favorable action on our forums. **
geposted Tue 01 Nov 11 @ 8:49 pm
