I couldn't find this through search so here's my question.
With the sampler I have the 12 sample slot mapped to F1-F12 which play when pressed, and stop when pressed again. Is there any action i could use in the mapper to change the second press to start the sample again? If it is possible I can't figure it out with my knowledge of the VDJ Script...
Thanks
Thanks
geposted Thu 24 Dec 09 @ 3:48 pm
Yes, simply change the action from sampler (N) play_pause to sampler (N) play_stutter
Or better, sampler (N) loop ? sampler (N) play_pause : sampler (N) play_stutter (This will allow you to start/stop looped samples and stutter non-looped ones (Otherwise you wouldn't be able to stop the loop!))
Replace (N) with the appropriate sample slot number.
geposted Thu 24 Dec 09 @ 4:29 pm
