Need help with the Netsearch. I'm trying to play the songs and it gives me Stream Unavailable. I'm new with the software and I trying to use that feature. I will appreciate any help with it. Thanks...
geposted Fri 25 Dec 09 @ 3:13 pm
I don't use this feature but I've read this problem was Fixed in 6.02, are you using the latest release? 6.05
https://virtualdj.com/download/updates.html
geposted Fri 25 Dec 09 @ 5:49 pm
Sometimes you need to re-enter your password in the config menu, to log in again. (even though it might say youre logged in already)
geposted Fri 25 Dec 09 @ 6:17 pm
