Hey!
My dad found his extremely old Sony SS-2030 Speakers and he is so passionate to use them. I think they are 30W nominal each and 50 W music...The sticker with all the info on it is gone so i googled and found these ratings here:
http://www.herefordequestrian.co.uk/classifieds/not_horsey.html
"Sony Speakers
Sony SS-2030
Nominal 30 w DIN. Music 50w DIN. Nominal Impedance 8.
Width 28cm, Depth just under 23 cms, height 50 cms "
And at their house there is this weird audio wiring that goes around every single room that they don't use. So basically I need to connect an amp to one end of the cable and the other end will be connected to Sony speakers upstairs. Very funky, i know...
I couldn't decide what to do...i need a cheap home amp for this i think..but i can't decide if i should go for 40 w each or 75w each... i thought 75w could be a good idea as long as they are careful with it as then they could use the same amp in other rooms too?
http://www.bhphotovideo.com/c/product/597468-REG/Pyle_Pro_PCA3_PCA3_Mini_2_x.html
http://www.bhphotovideo.com/c/product/597466-REG/Pyle_Pro_PCA2_PCA2_Mini_2_x.html
Would one of these work? Or any other suggestions...I am going to connect my old Numark CDN-34s to the amp...
Thanks...Happy holidays..
"Sony Speakers
Sony SS-2030
geposted Sat 26 Dec 09 @ 9:10 am
Wow, those speakers are old skool! 1978 i think! Yikes! Either amp is fine. If you think you're going to use the amp for other home applications, go for the larger one. If not, the 45 watt amp will be just fine. It's for your parents, and these are old school speakers. You're gonna want to be gentle!
geposted Sat 26 Dec 09 @ 6:59 pm
yeah i know..lol...they are ridiculously old skool...apparently they are from the first home audio system my dad bought...SO definitely i need to be gentle...that is why i wasn't sure about getting the 75W one but i think i would be fine if i keep the volume halfway thru maximum?
also where could i find similar amps? these were the ones i found first..never heard of the brand...could spend a lil bit more if i could get better one....thanks...
geposted Sun 27 Dec 09 @ 2:46 am
Why not check out some second hand amps.
There were quite a large number of fairly hi powered amps about in the late 80s up to the mid 90s. Kenwood/Technics and Sony all made some great amps in the 50 to 80W power bracket and most of them came with the facility to switch between system A and B speakers. You should be able to get hold of a realy good quality amp for verry little cash.
Daz.
Daz.
geposted Sun 27 Dec 09 @ 6:53 am
good plan...BUT i couldnt find a way out as i am not an expert on old skool technics/sony stuff...
there are millions of different models...and i think one big problem is they are all huge...i dont really have space for gigantic amps...
so i think i am better off getting a millenium amp instead...any help with that? thanks...
geposted Sun 27 Dec 09 @ 10:32 am
Generaly it pays top go for an amp which it more powerfull than the speakers as a low power distorted amp wil be more likely to damage your speakers. Even if they do eventually fail you can get inexpensive replacement drivers from lot of hobby component suppliers so dont panic if you do blow one.
Daz
Daz
geposted Mon 28 Dec 09 @ 11:18 am
so http://www.bhphotovideo.com/c/product/597468-REG/Pyle_Pro_PCA3_PCA3_Mini_2_x.html is the best i could get?
if these speakers turn out to be 30W would 75W work at 1/3 of the max volume? or not? i am worried...
also is there any other amp that does this kinda thing? cauz i checked music123.com, americanmusical.com and bhphotovideo.com but these are the only ones i could find...
if some1 could enlighten me before midday tomorrow i would really appreciate it as i need to order something before then...
thanks.... =))
thanks.... =))
geposted Mon 28 Dec 09 @ 6:23 pm
Hi mate
Looking at the spec for this little amp I notice that the power output is loosley quoted as 75W. It gives no information on how that figure is produced.
Most domestic HIFI speakers of this era were 8Ohm and most amps of todays era are intended to produce their max output int a 4Ohm load
(Ohms is a mesurment of the speakers internal resistance/impeadence and is used to match speakers and amplifiers together).
Without trying to get too complex this amp will normaly produce 75W ish into a 4 Ohm load. Your Sony speakers will be 8Ohm. This is not a problem but the amp will only deliver roughly half of its available power into the 8Ohm speakers. So about 40 W max. this will work fine and not hammer the speakers.
The other plus factor here is that the amp should be able to run 2 pairs of 8Ohm units at the same time.
There is unfortunately no corrilation between the volume control position and the output power of the amp. At the end of the day if it sounds distorted turn it down. You should not run into any major issues with this little amp as I suspect its claimed power output is somewhat flatterring;-)
Daz
Daz
geposted Tue 29 Dec 09 @ 4:51 am
Would this work :
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665788574
It is 100W X 2 though?
It looks like a better option to me...More to the point compared to a car audio looking amp...???
Thanks...
I mean would I be OK using 30W-50W speakers on a 100W amp?
PS. Hopes that someone will let me know in an hour so that I can get them before 31st...=))
Thanks...
geposted Tue 29 Dec 09 @ 2:36 pm
Hi mate
The Sony is a better amp but is rated for 100W into 8Ohms so is quite capable of frying those speakers.
In the budget range of HIFI amps you may want to have a look at some of the offerings from Rotel like the 1520 or even NAD's C315BEE.
Daz
Daz
geposted Tue 29 Dec 09 @ 4:27 pm
